Problem with DA Wizard
Thread begun 5/03/2011 7:44 am by giaino | Last modified 5/03/2011 8:06 am by Jason Byrnes | 1588 views | 1 replies |
giaino
When i use DA Wizard and set my result page with filter
FORM PARAMETER the page give me NO RESULTS but
if i try to test my recordset in DW it give me some results
i don't understand what's the problem please help me
I use DA 2.0.8 - DWCS5 - XP PRO SP3
This is the results page URL
"rdm/fatture_Results.asp?S_ID_fornitore=2&Search.x=44&Search.y=11&Search=Search"
and code generate recordset
Dim WADAfatture__GF_IDFornitore
WADAfatture__GF_IDFornitore = "-1"
If (request.form("ID_Fornitore") <> "") Then
WADAfatture__GF_IDFornitore = request.form("ID_Fornitore")
End If
Dim WADAfatture
Dim WADAfatture_cmd
Dim WADAfatture_numRows
Set WADAfatture_cmd = Server.CreateObject ("ADODB.Command")
WADAfatture_cmd.ActiveConnection = MM_RDM_STRING
WADAfatture_cmd.CommandText = "SELECT ID_fornitore, numerofatt FROM fatture WHERE ID_fornitore=?"
WADAfatture_cmd.Prepared = true
WADAfatture_cmd.Parameters.Append WADAfatture_cmd.CreateParameter("param1", 5, 1, -1, WADAfatture__GF_IDFornitore) ' adDouble
setQueryBuilderSource WADAfatture_cmd, WADbSearch1_whereClause, false
Set WADAfatture = WADAfatture_cmd.Execute
WADAfatture_numRows = 0
bye Giaino
Do not set any filtering on the results page.
The search and results page will automatically be configured to work together, the search page form will use the Get method, not the post method, meaning there will not be a form post to the results page, the search criteria will be passed using URL variables.
