DFP / UE4 Bug
Thread begun 5/01/2011 4:24 pm by Paul | Last modified 5/03/2011 11:58 am by Paul | 1728 views | 2 replies |
PaulBeta Tester
DFP / UE4 Bug
I think there is a bug in these extensions that prevents them working as expected with CS5 php templates.
Can you check and advise please.
The only way i can get these working is to detatch my template, which is a workaround i'm not happy with.
Thanks, Paul.
What is the error you are getting? If it is:
You have made changes to code that is not marked as editable. If you retain those changes, they will be lost the next time you apply a template update to this file. Do you want to retain the changes until then?
This is more of a Dreamweaver Issue, see the following post:
showpost.php?p=18157&postcount=2
PaulBeta Tester
Yes, I figured the workaround.
Its frustrating having a couple of docs that require manual intervention when the rest of the site is based on .dwt!
Thanks for the response anyway.
