Download Centre - Blank Page
Thread begun 5/01/2011 4:50 am by Kamen Nikolov | Last modified 5/03/2011 11:32 am by Jason Byrnes | 9527 views | 13 replies |
Kamen Nikolov
Hi everyone,
I have build Download center and it doesn't post the files into the download center at all. I have looked and looked for a problem why it is not working and I am not seeing it. I am attaching the confirm.php and the download_center.php.
Please help.
Kamen
a blank page means that a php error is occurring but error reporting is disabled.
add the following code at line 1 of the download center page:
error_reporting
(E_ALL);
Kamen Nikolov
This is what I got:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /hermes/bosweb26b/b2452/ipw.thewealthquestcom/public_html/download_Center.php:5) in /hermes/bosweb26b/b2452/ipw.thewealthquestcom/public_html/WA_SecurityAssist/Helper_PHP.php on line 5
and these are the lines (4-6) from Helper_PHP.php:
if (!isset($_SESSION)) {
session_start();
But I just notice this on line 14 of Helper_PHP.php:
mysql_select_db($WA_Auth_Parameter["database"], $WA_Auth_Parameter["connection"]);
Isn't ["database"] be the dataBase Name and ["connection"] dataBase Connection?
see this post for details on troubleshooting the headers already sent error:
showthread.php?t=19285
Kamen Nikolov
Hi Jason,
I have checked the attached post and I have check my files non of it is applicable. Any other ideas. I can send you all file so you can take a look.
Thank you
pay atention to this part of the error message:
this is telling you to look at lines 4 and 5 of the download_Center.php page for the cause of the error.
the most likely cause is a blank space at the end of the closing php tag:
Kamen Nikolov
Hi Jason,
I have tried your suggestion and it is giving me the same result. After buying the product they will receive en email directing them to their profile where they can accesses the download center. (Picture-1) When they click the Download Center Button it takes them there. The problem is it is blank/empty it doesn't show anything in the download center. (Picture 2)
There is a problem some where and I cant find it.
This is not the same as a blank (white) page, a blank page indicates that there is nothing at all showing,
Instead, this is telling you your recordset is not pulling any results.
Looking at the confirm page, I can see that the store order summary behavior is not storing the logged in users ID.
On the confirm page, double click the Store Order Summary server behavior. Bind the OrderUserID column to the UserID session variable.
Kamen Nikolov
Which line is that? I am looking at the code and I am not seeing it. I must be going blind, I am so sorry.
it's not a line.
Open the server behaviors window. Go to Window -> Server Beahivors.
in the list of Server behaviors, locate the eCart Store order Summary server behavior. double click on it to edit the settings.
bind the orderuserId column to the User ID session variable.
for more details, see the "Applying Register/Login to your checkout" tutorial on the eCart support page:
ecart/
