Date storage issue
Thread begun 4/29/2011 3:36 pm by web_assist_mail157665 | Last modified 5/02/2011 1:19 pm by Jason Byrnes | 2744 views | 4 replies |
Date storage issue
I have insurance dates that are formated to appear by PHP to appear DD-MM-YYYY
this form info needs to be stored with an order (summary)
Opening the store Cart Summary SB (view columns against values)
and checking the DB Column InsuredPolicyExDate - I get type text
the DB field it refers to is type DATE
I set the field to date - but this is never saved and it reverts to TEXT?
and I just get a blank entry 0000-00-00 in my order
AS a last resort I set it to MSDATE (which stuck - but I get a MYSQL error on insert)
Is this the SB interface not working correctly
Note: There's obviously no way for the cart to know the format of the date is
Suggest this feature is added to the cart general settings - page 1
I need a way to get from the human readable
DD-MM-YYYY
php formatted display date
back into the correct format for the summary insert
if the text is entered
DD-MM-YYYY
then
// convert back the dates to mysql format
//list($d,$m,$y) = explode('-',$_SESSION['insure_date']);
//$_SESSION['insure_date'] = $y."-".$m."-".$d;
//list($d,$m,$y) = explode('-',$_SESSION['health_date']);
//$_SESSION['health_date'] = $y."-".$m."-".$d;
seems to do the trick if I echo it directly to the page to check it visually
but I still get 0000-00-00 in my database insert?
please advise
CraigRBeta Tester
i had a similar thing recently with the datpicker extension.
take a look at this thread, you could modify the function to suit your needs...
showthread.php?t=17864
(Thanks to Dave Buchholz for the idea)
neilo
Also see thread showthread.php?t=9484&page=2
Thanks guys
A combination effort got things working
2 Things
1/
Still looks like there's a bug in the ecart 5.01 interface
I can't set the datatype to DATE only TEXT NUMBER or MSDATE in the SUMMARY to DATABASE SB
most odd
2/
Date formatting should be in the general settings in the Cart setup first tab
In MySQL, a string and date are treated the same. a date is passed the same as a text string in my sql:
'text string'
or
'2011-5-2'
you can get around these date formating issues by using a varchar columns for your dates, a MySQL date column will need to use the yyyy-mm-dd hh:mm:ss format
in a varchar column you can store the more familiar 5/2/2011 format. If you are going to use a data column type, then you will need to reformat the date to the expected format.
