Add to Cart Button within repeat region (dynamic)
Thread begun 4/28/2011 10:52 am by Andrew Read | Last modified 4/29/2011 10:52 am by Andrew Read | 2800 views | 4 replies |
Andrew Read
Hello,
I have created a Add to Cart button and it is within a repeat region on a php page. It does generate a form and button for each product that is in my recordset, however I get the following error when I try to add an item to the cart:
  Notice: Undefined variable: ATC_itemQuantity
I have scoured this forum and found references to a "Dynamic Add to Cart Button within repeat region" tutorial or guide, but I'll be darned if I can find it anywhere within the support area.
Any help or suggestions on this one?
please post a copy of your page and a link where i can see the problem to investigate the cause.
Andrew Read
Hi Jason,
Please open a ticket, as per general practice I won't be posting the links to the pages or the code on the open forum.
I will however certainly share the solution to this issue once we figure it out, and possibly create a tutorial for this once we sort it out.
Thanks.
Ok, I have started a ticket for this.
Andrew Read
For those looking for the solution:
1. The product details recordset was in the code shortly before the "Add to Cart" form and button that displays with each individual item on the page (within a repeat region.)
2. The 'add to cart behaviour' was near the top of the page, just below the regular page recordsets.
3. The add to cart behaviour needed the information about the products that was within the repeat region - BELOW/AFTER the add to cart behaviour code.
4. Situation was resolved by creating a duplicate recordset at the top of the page BEFORE the add to cart behaviour which contained the informatino for all available items, allowing the add to cart behaviour to reference the item properties.
I hope this helps others.
