Log In Failure
Thread begun 4/28/2011 6:03 am by gpaul | Last modified 4/28/2011 10:54 am by Jason Byrnes | 6889 views | 9 replies |
gpaul
Log In Failure
I have a log in that does not work, upon entering app_uname (username) and app_pw (password), the input data is removed and it appears the page reloads. The failure redirect is set to another page, however it does not take me there.
I have uploaded the HelperGroupsRulesPHP.php and it has the rule included (I have another log in on the site that works).
The connection seems to be correct in that I am able to insert into the DB and the connection files are the same.
This is from appraiser_LogIn.php
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $assess_remote,
"database" => $database_assess,
"tableName" => "appraiser",
"columns" => explode($WA_Auth_Separator,"app_uname".$WA_Auth_Separator."app_pw"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"app_id"),
"sessionNames" => explode($WA_Auth_Separator,"app_id"),
"successRedirect" => "appraiser_Profile.php",
"failRedirect" => "appraiser_EmailPW.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
if((((isset($_SESSION["app_id"]) && $_SESSION["app_id"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
"columnValues" => explode($WA_Auth_Separator,"".((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") ."".$WA_Auth_Separator."".((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") .""),
"failRedirect" => "index.php",
Is there any other information that would be helpful in tracking this down?
Thank you
Gary
sounds like a php error is occurring that is preventing the redirect.
add the following code at line 1:
[php<?php
error_reporting(E_ALL);
?>[/php]
post back a copy of your login page in a zip archive and any errors that show after testing.
gpaul
Jason
Thank you for your reply, nothing happened when I inserted
However, the url then reflected this:
law_firm_LogIn.php?accesscheck=%2Fappraiser_Profile.php%3Faccesscheck%3D%2Fappraiser_LogIn.php%3F%26accesscheck%3D%252Fappraiser_Profile.php%253Faccesscheck%253D%25252Fappraiser_LogIn.php%25253F
Find attached the log in page.
Thank you for your help.
Gary
Hmmmm, in the login page, add the following code just before the </body> tag:
<pre><?php var_dump($_SESSION); ?></pre>
and send a copy of the profile page and HelperGroupsRulesPHP.php page in a zip archive.
gpaul
Jason
I have attached the two files as well as the appraiser_LogIn.php page.
Again nothing happened when I added the error reporting script.
Thank you
Gary
I dont believe the changes I am asking you to make on the login page are making it up to the server.
If they where, i should see:
array (0) { }
bellow the footer on the login page but I am not.
To double check this, add today's date:
4/28/2011
just after the opening <body> tag. this visual change to the page will help ensure the changes are making it up to the server.
gpaul
I think that you are on to something, I put the date in, uploaded the page, it showed that the update had been made (the file appraiser_LogIn.php reflected the new modified time), however the changes did not show in the browser.
When I enter the page, it is
appraiser_LogIn.php
After I enter the log in information, the url is now
It appears there is a redirect to law_firm_LogIn.php, which is the other log in page I have on the site.
When I do an incorrect log in on the law_firm_LogIn.php page, the url does not change....hope that helps.
What should I try next?
Gary
change this code on the login page
if (!WA_Auth_RulePasses("Logged in to appraiser")){
WA_Auth_RestrictAccess("appraiser_Profile.php");
if (WA_Auth_RulePasses("Logged in to appraiser")){
and on the profile page, change:
WA_Auth_RestrictAccess("law_firm_LogIn.php");
WA_Auth_RestrictAccess("appraiser_LogIn.php");
gpaul
Jason
Thank you for your help, that seems to have solved it.
Gary
glad to hear it is working.
