Integrated in admin for site sculpture
Thread begun 4/27/2011 5:42 pm by randyw2394710 | Last modified 4/28/2011 5:51 am by Ray Borduin | 1762 views | 1 replies |
randyw2394710
I have web site created from site sculpture. It has an admin section.
admin/
I would like to put the admin From powermessenger into the same admin as that
instead of
admin
Is that possible I'm having troubles
You would have to copy an existing theme and create a template from your site sculptor template and put it in the webassist/themes/[your new theme name]/templates/ folder and make sure it has the same editable region names as the powermessenger template you replace.
Then just add the pages from powermessenger to your site sculptor menu so that you can navigate to them.
If you need our help, then sign up for a phone support incident and someone will be able to walk you through everything necessary.
