Power Gallery Display issues with IE 9
Thread began 4/27/2011 1:59 pm by sdeane76276 | Last modified 5/20/2011 11:20 am by Jason Byrnes | 2247 views | 7 replies |
sdeane76276
There seems to be an issue with PowerGallery and IE 9. The gallery is appearing fine in all other browsers. Here's and example URL: interior_apartment_renovation.php
Is anyone else having this issue? If so, have you found a fix?
Thanks in advance!
We will have an update available soon to address this issue, should be this week, or early next week.
niel405715
Internet Explorer 9 - Problem
A fix is needed urgently as more and more people are starting to use IE 9. My clients are complaining that they can’t view the galleries on my web pages!!!
There is a fix available for this in the Known Issues section of the power gallery download center page.
nicola.goodenough317043
Same problem in PG previous release
Dear Jason,
I have the problem (gallery not showing on homepage in "Site Message" area, and galleries not working on Product Details pages) for an existing customer on a previous release of PowerGallery.
I can follow your instructions to upload the Galleries folder, but I am not sure about the WA / cashing ... Should this be at the same level as the WA_SecurityAssist folder under PowerGallery, and should it follow the same naming convention (WA_Cashing)?
Many thanks, Nick
at the same level as the WA_Security assist folder, there should be a folder named webassist.
inside the webassist folder, create a new folder named "caching"
place the CachedResize_Image.php file inside the webassist/caching folder
Folder level
Dear Jason,
In neither my PowerGallery folder, nor in my PowerStore folder, do I have a folder which is just called "WebAssist". Is this because this site was set up originally in 2009, and you have had subsequent releases of your products where a new folder structure is implemented?
I have attached jpg showing the folder structure of my customer's site. WA_PS_PG_ie9 shows from root of PS, WA_PG_ie9 shows from root of PG.
create the webassist folder at the root of the site then create the caching folder inside it.
