Server validation causes dreamweaver to crash
Thread begun 4/27/2011 9:56 am by andre381452 | Last modified 1/09/2012 8:53 am by randy299647 | 4366 views | 6 replies |
andre381452
I have CSS Form Builder 2.0.0 installed. I do not have HTML editor. I use Dreamweaver CS4. When I add server validations to a form as soon as I add a second element to validate Dreamweaver crashes. I have tried removing and re-installing. No luck. Any advice greatly appreciated.
regards.
Andre
Delete the Dreamweaver Cache file from the users configuration folder:
andre381452
no joy
I removed the MacFileCache.dat file and restarted CS4, same crash.
Un installed CSS form builder 2, re-installed, MacFileCache.dat checked and not there, re-started CS4 and crashed again.
Any ideas?
randy299647
Server validation causes DW CS5.5 to crash
I'm having the same problem -- DreamWeaver CS5.5 crashes when I try to insert the second server validation. I have no Mac cache file.
you should not be adding a second server validation behavior.
use one server validation behavior to validate all of the form elements on the page.
select the validation type, select the server variable to validate, then click the plus button to add it to the list of validations that will be performed.
repeat this for each form element.
randy299647
That works! Thanks!
