cURL not loaded
Thread begun 4/27/2011 5:28 am by alistair316863 | Last modified 4/27/2011 8:26 am by alistair316863 | 3414 views | 4 replies |
alistair316863
cURL not loaded
Hi when I run the gallery instalation wizard I get "cURL is not installed. Contact your hosting provider to have cURL installed."
Yet if you goto: phpinfo.php you will see that cURL is enabled any ideas regards Alistair
most likely the server is blocking the connection to the webassist server.
create a new page and add the following code at line 1 to test the cURL connection to the webassist servers:
error_reporting
(E_ALL);
$c = curl_init();
curl_setopt($c, CURLOPT_URL, "https://www.webassist.com/");
curl_setopt($c, CURLOPT_TIMEOUT, 90);
curl_setopt($c, CURLOPT_POST, 1);
curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 0);
curl_setopt($c, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($c, CURLOPT_POSTFIELDS, "");
$result = curl_exec($c);
if(!
curl_errno($c)){
$info = curl_getinfo($c);
  echo
'Took ' . $info['total_time'] . ' seconds to send a request to ' . $info['url'];
} else {
  echo
'Curl error: ' . curl_error($c);
alistair316863
done the url is: gallerytest.php
but the answer was: Curl error: SSL: certificate subject name 'FG300B3908602133' does not match target host name 'www.webassist.com'
I think this may be an issue with the older cURL library installed on your host server version 7.15.5.
the version currently available id 7.21.6, contact your host to have them update the libcurl.dll to the newer version.
alistair316863
cheers Jason I will ask them to update it and let you know
