Same as billing address box is not working on check out page
Hi all, I guess must be something silly but for some reason the feature is not working. On the check out pahe, you type in all the data for the billing information, if you check on the box that says "Same as billing address" nothing happens, meaning is not populating the shipping fields with the billing info as it is supposed to be doing. I thought maybe it doesn't populate there but gets saved on the database and on Authorize.net (my payment gateway in this case). I found that nothing gets saved on the database or authorize.net database.
What I'm doing wrong?
Thanks!.
