File Not Uploading
Thread begun 4/26/2011 3:13 am by Lee Firth | Last modified 4/26/2011 1:52 pm by Jason Byrnes | 2512 views | 3 replies |
Lee Firth
File Not Uploading
I am posting here as I believe the WebAssist->File Manipulation->Upload behavior is part of the Universal Email extension. I have run the DataAssist wizard which has generated the insert page. To this I have added a HTML Editor and a file field to which I have applied the file upload SB to generate the details and thumbnail images. My problem is that the file doesn't upload to the server and there are no errors. I have followed the "Applying Digital File Pro to your Insert page" tutorial. Here is the generated code or the file upload & insert record SB's.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../product_images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "250",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "../product_images/thumbnails/",
'FileName' => "[FileName]_thumb",
'ResizeWidth' => "100",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(
$_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "products_image", "0", "", "JPG:80", $WA_UploadResult1_Params);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $harrisda_data;
$WA_table = "products";
$WA_sessionName = "WADA_Insert_products";
$WA_redirectURL = "products_Results.php";
  if (
function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "product_id";
$WA_fieldNamesStr = "categories_id|products_model|products_description|products_image|products_sort_order";
$WA_fieldValuesStr = "".((isset($_POST["categories_id"]))?$_POST["categories_id"]:"")  ."" . "|" . "".((isset($_POST["products_model"]))?$_POST["products_model"]:"")  ."" . "|" . "".((isset($_POST["products_insert"]))?$_POST["products_insert"]:"")  ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."" . "|" . "".((isset($_POST["products_sort_order"]))?$_POST["products_sort_order"]:"")  ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL";
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_connectionDB = $database_harrisda_data;
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
The First thing to check is the form encoding type.
Make sure that the forms encoding type is set to multipart/Form-data
if the upload is still failing, edit this line:
$WA_redirectURL = "";
then add the following code at line 1:
error_reporting
(E_ALL);
then from the bindings panel, expand the WA Uploaded Files Global Status group and add the debug info binding to your page.
post back the results after testing.
Lee Firth
Once I set the enctype property of the form to "multipart/Form-data" it worked, thanks Jason.
glad to hear it is working.
