Email Contents
Thread begun 4/25/2011 5:08 pm by mora398588 | Last modified 12/20/2011 6:17 am by sabastian130416448 | 5490 views | 8 replies |
mora398588
Email Contents
When I was testing the sending of any email from a form I just created, I noticed that the email was missing some of data the form included, such as the address 1 and address 2 data. All of the other data was present in the body of the email. What may be the issues I'm facing? Have there been other related issues?
I am using UE4 with current updates.
I have attached the email template for your review. The form I created and used for my test is at cu_registration.
the problem is that you have spaces in your form element names. For example:
<input type="text" id="Address 1" name="Address 1" autocomplete="off">
Form elements names may not contain spaces. The following rules should be followed when naming form elements:
1) Only Alpha numeric character can be used, the only exception is the underscore "_"
2) The first character must be a letter.
mora398588
Thank you for your reply.
What you said made perfect sense. When I made the changes, the changes did not make any difference.
I noticed the the first and last name text fields also have spaces and the data is showing up in the email body.
At this point, I am back to square one.
You are free to view the form. I am sending you a copy of the file that contains the form.
the URL is in my last post.
make sure that your text boxes also have a value attribute:
<input type="text" name="Address_2" id="Address_2" value="">
you have many form elements in this for that are not properly named, for example:
<input name="Master's Certificate Program?" type="checkbox" id="MastersCertification" value="Yes">
you will need to fix all of them and use proper naming on all of them.
mora398588
Jason, I went back and corrected my form elements. However, the email contents are still missing the address 1 and 2 information. Everything else is coming through fine.
I have provided updated file for your review.
Testing your files on my server, the address 1 and address 2 information is being sent in the email properly.
make sure your updates are being uploaded to the server correctly.
I still see some bad element names in your form:
<input name="Master_Certificate_Program?" type="checkbox" id="MastersCertification" value="Yes">
your form element names may only contain letters and numbers. The only exception is the underscore character.
mora398588
Jason, thank you for taking the time to test my files.
I went back to testing my files again, and still I am running into the same problem. The address fields are not showing up in the body of the email. I even tried using a new template in UE (Blank.php) to see if the template I was using previously was the problem. It did not make a difference - the address fields were left out.
Here is what I am uploading to my server:
1. mailformatting_php.php
2. waue_cu_registration_2.php (I updated the UE server behavior a second time to start fresh)
3. cu_registration.php (email template file)
4. cu_registration.php (actual web form)
Is there anything I am leaving out?
sabastian130416448
Hi Jason.
I am having the same problem and I tried all the steps that you layed out so far but still no luck.
This is the address to my thread where I have my files uploaded aswell showthread.php?t=24196
Hope we can find an answer cause this is driving me crazy.
