Item Added to Cart Message
Thread begun 4/24/2011 6:28 pm by etekLab | Last modified 4/23/2014 8:38 am by Jason Byrnes | 3703 views | 5 replies |
etekLab
The product page has multiply items and one add to cart button. On one page there is 50 items check box and one add to cart button which is working fine. My question is once the customer selects the checkbox and clicks on add to cart button I want a message to show next to the product telling them the item is added to cart so they do not double order it.
Is there a way so the customer can see a message next to the product telling them they have already added the product to the cart.
next to the add to cart button code in the repeat region, you can add this code to show the message:
<?php if($yourCartObject->InCart($row_RecordsetName['IDColumn']) == true) echo("This item has been added"); ?>
Where "yourCartObject" is the name of your eCart object, "RecordsetName" is the name of the products recordset and "IDColumn" is the name of the ID Column in your products tabel.
etekLab
Thank you very much, the code works fine.
you're welcome.
pedstone
This works great - thanks Jason
Now I have a similar case where the same product has 2 variations.
Example: T-Shirt color blue or red
So I added a column to the cart for the color and added an add to cart button for red and another for blue.
How could I show now a message if a blue or a red T-shirt was added to the cart?
Another thought was also if it would be possible to remove the add to cart button if the item is in the cart and to replace it with
the message that the item is in the cart.
Meanwhile I found a solution here: http://www.webassist.com/forums/posts.php?id=26621
It works great for what i need it - thanks again Jason
maybe it would be nice to have this as a behavior in some future releases of ecart
glad to hear you have it working.
