using with powerstore
Thread begun 4/24/2011 11:58 am by i.edwards384429 | Last modified 4/24/2011 12:31 pm by i.edwards384429 | 2244 views | 2 replies |
i.edwards384429
Hi
installed powerstore 3 and created the following connection
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_PowerStoreConnection = "localhost";
$database_PowerStoreConnection = "test";
$username_PowerStoreConnection = "ian";
$password_PowerStoreConnection = "starwood";
$PowerStoreConnection = mysql_pconnect($hostname_PowerStoreConnection, $username_PowerStoreConnection, $password_PowerStoreConnection) or trigger_error(mysql_error(),E_USER_ERROR);
I then created one using dynamic connections
# FileName="WADYN_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$password_PowerStoreConnection = "starw00d";
@session_start();
The second throws up errors as shown in the attached file
Any ideas why?
thanks
Ian
It appears the password is wrong. Why did you change the password in the dynamic connection?
i.edwards384429
update
Hi Ray
thanks
looked at that for hours and missed that important fact
cheers
Ian
