PHP Errors
Thread begun 4/24/2011 8:39 am by sysop349733 | Last modified 5/31/2011 7:28 am by sysop349733 | 4193 views | 6 replies |
sysop349733
PHP Errors
I'm seeing the following errors/warnings in my server's error log file:
PHP Warning:  DOMDocument::load() [<a href='domdocument.load'>domdocument.load</a>]: Extra content at the end of the document in /home/altmediaadmin/www/greensboro101.com/htdocs/includes/_promaps_cache/_promaps_geocache.xml, line: 3 in /home/altmediaadmin/www/greensboro101.com/htdocs/includes/google_javascript/promaps_geocache_php.php on line 21, referer: http://www.greensboro101.com/includes/EventsMap.php
PHP Fatal error: Call to a member function appendChild() on a non-object in /home/altmediaadmin/www/greensboro101.com/htdocs/includes/google_javascript/promaps_geocache_php.php on line 36, referer: http://www.greensboro101.com/includes/EventsMap.php
Lines 21 and 36 of promaps_geocahce_php.php referenced in the errors are as follows:
21: $dom->load($xmlFile);
36: $geocodeEntry = $root->appendChild($geocodeEntry);
And here is the _promaps_geocache.xml file
<?xml version="1.0" encoding="UTF-8"?>
<geocode_data version="1.0"><geocode_entry ID="113 N. Greene St. Greensboro NC 27401 U.S."><address><![CDATA[113 N. Greene St., Greensboro, NC, 27401, U.S.]]></address><geocode><![CDATA[(36.073109, -79.792041)]]></geocode></geocode_entry></geocode_data>
How can I eliminate these errors?
Dani Chankhour
Can you please post a link to the page that has the map on it so i can debug the issue further, but looking at the errors that you are seeing, it could be possible that you have a version of PHP that does not support the DOMDocument.
Thanks.
sysop349733
Reply
I am running PHP version 5.2.17 with DOM/XML enabled.
The page generating the error is: EventsMap.php
It is being included via i-frame on www.greensboro101.com
sysop349733
Resolved -- Permissions error
Got a call from tech support today. The issue has been resolved. The permissions were too strict on the _promaps_geocache.xml file in the _promaps_cache directory.
Thanks for the help.
gamedbs398030
Can you share the solution for us?
Originally Said By: sysop349733
I also had this type of problem while running the firebug with Firefox browser.
Can you share the information from Webassist on how to resolve this problem? Thanks
sysop349733
Permission
Originally Said By: gamedbs398030
I don't remember the exact settings, just incrementally increase your permissions for the web user on the cache file until you no longer get the error.
