After 4.5 Update - Product Download Problem
Thread begun 4/23/2011 10:31 am by documech421157 | Last modified 6/07/2011 10:29 am by Jason Byrnes | 3245 views | 5 replies |
documech421157
I just updated from PowerStore 4.0 to 4.5. So far, everything seems to work, but when I enter the "Download Center", every download product says "No File Found". I added a new download product, and it does the same thing. It correctly displays the product, and correctly shows how many downloads are left, but the download button is replaced with "No File Found." The product design page for each download product correctly shows the download file, and I can update the download file and it all seems to respond as before. The "No File Found" error is the only problem I've seen after the update, but since I only sell download products any help would be appreciated. Thanks.
david390068Beta Tester
Any update on this?
Was there ever a resolution to this? I am having the same problem. Product uploads fine. But in download center shows no file found.
Here is an updated copy of the view_downloads.php file that should correct the problem.
Thanks Jason. I replaced the file. No luck. Same error.
