Whats the core on this one?
Thread begun 4/23/2011 7:11 am by Steve | Last modified 4/25/2011 1:54 pm by Ray Borduin | 2752 views | 3 replies |
Steve
In other words is this built on PHPList 11 (or 10)?
I've been meaning to roll out a similar marketing product on my server but have not had the time. I'm big on buying and extension if it will save me time in the future.
The current problem with PHPList is that it takes some work to have the various templates display only for specific Admins. Surmount that problem and you've got a killer marketing tool to offer your clients.
Any feedback on if this extension/solution is either based on the same core noted or allows multiple Admins that can manage their own email marketing campaigns?
This is a custom solution built with webassist tools... primarily framework builder, html editor, data assist, security assist, and universal email. It does not use PHPList.
Steve
Thanks for that info Ray.
Couple more questions:
1) is there any throttling controls so as to make sure while sending out a campaign it is not done in such a manner to take too many resources from a server? ( I run my own dedicated server )
2) Does it look like it would be easy to allow different Admins to see only their users and templates?
1) Yes you can set a delay between emails as well as setting the maximum number in a time period... so you could set it to send emails one second apart and send up to 1000 per half hour for instance.
2) You would have to add a field to the database to keep track of the owner and then filter based on that field. It isn't built in, but it should be relatively easy if you are familiar with dynamic web sites and Dreamweaver.
