Conflict with Facebook "like" plugin?
Thread begun 4/23/2011 6:36 am by Steve | Last modified 4/26/2011 1:43 pm by Jason Byrnes | 7224 views | 7 replies |
Steve
Hello,
Here's an odd one...
Take a look at this page:
isemanhomes.com/
On the left vertical nav there is a Facebook "like" button that is generated from the facebook developer site.
Now mouse of one of the links in that same area... Facebook link/plugin disapears.
The page uses the nav area as an include via Framework plugin. And the menu is a Spry Menu group. I looked at the page using Firebug which usually will show you things that act dynamically but in this case the plugin contents for facebook still exist after the mouseOut, I just can't see what or where is the cause.
Anyone have some greater tools or insight into this condition?
Regards,
Steve
What browser are you using for testing?
I do not see this behavior in Fire Fox 3 or 4, IE8 safari or Google Chrome.
I am not able to reproduce this problem.
Steve
All browsers show this problem.
Right now I have the like button twice in the left vertical column. The top one does not disappear when you mouse over a link but the one just above the You Tube link does.
add a container to the facebook like code:
in your source I see:
<div id="fb-root"></div>
<script src="http://connect.facebook.net/en_US/all.js#xfbml=1"></script><fb:like href="http://www.facebook.com/pages/Iseman-Homes-Youre-Home-Now/177004345682853" layout="button_count" show_faces="true" width="144" font=""></fb:like>
try changing that to:
<div id="fb-root">
<script src="http://connect.facebook.net/en_US/all.js#xfbml=1"></script><fb:like href="http://www.facebook.com/pages/Iseman-Homes-Youre-Home-Now/177004345682853" layout="button_count" show_faces="true" width="144" font=""></fb:like></div>
Steve
I had tried a container prior and no luck. But I have moved the closing div tag as suggested and updated the live page. Problem still present.
you should also have a div container around the navifgation UL:
<div>
<ul id="MenuBar1" class="MenuBarVertical">
<li><a href="aboutus.php">About Us</a> </li>
<li>
<a href="#" class="MenuBarItemSubmenu">Available homes</a>
<ul>
<!-- start dynamic list -->
<li><a href="inventory.php?invtype=35">Brainerd, MN</a></li>
<li><a href="inventory.php?invtype=5">Chillicothe, MO</a></li>
<li><a href="inventory.php?invtype=10">Gillette, WY</a></li>
<li><a href="inventory.php?invtype=7">Kearney, NE</a></li>
<li><a href="inventory.php?invtype=1">LeMars, IA</a></li>
<li><a href="inventory.php?invtype=6">Minot, ND</a></li>
<li><a href="inventory.php?invtype=11">Pierre, SD</a></li>
<li><a href="inventory.php?invtype=8">Rapid City, SD</a></li>
<li><a href="inventory.php?invtype=4">Sioux City, IA</a></li>
<li><a href="inventory.php?invtype=9">Sioux Falls, SD</a></li>
<li><a href="inventory.php?invtype=28">Williston, ND</a></li>
<!-- end dynamic list -->
</ul>
</li>
<li><a href="contact.php">Contact Form</a></li>
<li><a href="faq.php">Iseman FAQ</a></li>
<li><a href="LocationsMap.php">Locations</a></li>
<li><a href="Builders.php">Iseman's quality builders</a></li>
<!-- <li><a href="map.php">Map (w/Phone Numbers)</a></li> -->
<!-- <li><a href="financing.php">Financing Information</a></li>-->
<li><a href="#" onclick="MM_openBrWindow('mortCalc.php','calc','width=480,height=350')" ><img src="img211/calculator.gif" alt="Calculator" width="14" height="14" border="0" align="absmiddle" />&nbsp;Mortgage Calculator</a></li>
</ul>
<!--End Sidebar Nav-->
var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
</script>
</div>
Steve
Jason, good job...
that second container div around the line items fix it.
Thanks,
Steve
Glad to hear it is working.
