Table 'pcms2_users' doesn't exist
Thread begun 4/22/2011 2:17 pm by thehermitvi425323 | Last modified 6/19/2014 7:32 pm by Jason Byrnes | 3106 views | 5 replies |
thehermitvi425323
Yet another one with the table not existing. I looked at the sql file and there is no code to create this table. Is there a reason for this?
Without it PowerCMS doesn't work.
Is it possible for you to post the sql for this table and I can create it myself or is it a deeper problem than that?
The sql to create the pcms2_users tabel is:
CREATE TABLE IF NOT EXISTS `pcms2_users` (
`UserID` int(11) NOT NULL auto_increment,
`UserEmail` varchar(500) default NULL,
`UserPassword` varchar(500) default NULL,
`UserFirstName` varchar(50) default NULL,
`UserLastName` varchar(50) default NULL,
`UserCity` varchar(90) default NULL,
`UserState` varchar(20) default NULL,
`UserZip` varchar(12) default NULL,
`UserEmailVerified` tinyint(1) default '0',
`UserRegistrationDate` timestamp NULL default CURRENT_TIMESTAMP,
`UserVerificationCode` varchar(20) default NULL,
`UserIP` varchar(50) default NULL,
`UserPhone` varchar(20) default NULL,
`UserFax` varchar(20) default NULL,
`UserCountry` varchar(20) default NULL,
`UserAddress` varchar(100) default NULL,
`UserAddress2` varchar(50) default NULL,
`UserGroupID` int(11) NOT NULL default '1',
PRIMARY KEY (`UserID`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8;
if you have other problems, let us know and we will look into it.
pistartech366237
Hello Jason,
I've installed Power CMS on the website. However, after the installation, I've deleted the install_cms folder on the remote server and successfully logged in. When I've uploaded the page with CMS content, it has given me an error "Table xxxxxxx, pcms2_toolbardefinitions doesn't exist". I've searched the forum and saw one post with the same problem, but it didn't have a solution. So, I've tried different things, however, it didn't help.
I've removed all folders created by Power CMS on both - remote server and local. I've replaced the page with its copy that I've made right before I've applied the Power CMS, and have started the process again (i.e. uploaded all files, dropped all previously created tables), however, the solution didn't automatically redirect me to install_cms/index.php page. Instead, it would redirect me to the CMS Login page, which does not work since I have brand new tables in the database and have not created the users yet.
It is a mess.... and I need your help as always.
Please read the PM for info:
Thank you so much in advance.
to restart the installation, delete the installed.txt file in the Connections folder. that will allow you to start the install again.
pistartech366237
Dear Jason,
Your customer service is beyond excellent!!! Thank you - the installation worked, and CMS system works as well!!!
Thank you so much!
Have a good night!
Glad to hear it is working.
