Universal Email 4.0.1
Thread begun 4/22/2011 7:17 am by michaelf0199272 | Last modified 4/22/2011 6:33 pm by michaelf0199272 | 2077 views | 2 replies |
michaelf0199272
There are to issues:
1) when I complete the form and it is submitted --- it seems like it is sent but I did not receive the test email from sending the submission. It loaded the thank you page with out any sign of problem.
2) when I trred to launch waue_contact_usbb_1.php inside the hosting server, I got the error below
Fatal error: Call to undefined function waue_definition() in /misc/39/000/158/672/0/user/web/testsite312.bravehost.com/Jason/webassist/email/waue_contact_usbb_1.php on line 15
Q: Do you have any suggestion as to why these two issues are coming up??
Find the link below:
contact_usbb.php
Thanks.
Since the page is being redirected to ht e thank you page, It means that Universal Has compiled the email and has passed it on to the SMTP server.
If the email is not being received, it means that the SMTP server has refused to relay the email message.
Double check with your host that you are using the Correct SMTP server in the universal Email settings.
you nay also want to make sure that the from address is set to a valid email address for your hosting domain. Some SMTP servers will refuse to relay the email if the from address is not a valid address for your domain.
On the email settings you may also need to check the option to Include the from address as an extra parameter.
as for the error you are getting, the webassist/email/waue_contact_usbb_1.php file is not intended to be accessed directly. when UE is applied to your form page, a require_once line is added to attach the webassist/email/mail_php.php which defines the waue_definition() function.
michaelf0199272
I modified the form to include more options and now the form which at least was making submission is now coming up with error messages>
"...Warning: require(Block.php) [function.require]: failed to open stream: No such file or directory in /misc/39/000/158/672/0/user/web/testsite312.bravehost.com/Jason/webassist/email/mailformatting_php.php on line 142
Fatal error: require() [function.require]: Failed opening required 'Block.php' (include_path='.:/usr/share/pear') in /misc/39/000/158/672/0/user/web/testsite312.bravehost.com/Jason/webassist/email/mailformatting_php.php on line 142"
Ignored please --- block.php has been uploaded.
