repeat regions
Thread begun 4/20/2011 3:36 am by ijs174940 | Last modified 4/20/2011 9:52 am by ijs174940 | 1552 views | 1 replies |
ijs174940Beta Tester
repeat regions
Apologies if this has been dealt within the forum but I could not find any post relating to this via the forum search.
My issue is using the plug in inside a repeat region, as the item in question need to be numbered incrementally how can I pass the value to it as the script that calls it is outside the repeat region in the header of the document, I have tried setting up a $_SESSION but it is not an ideal solution, surely you should be able to pass vars to the plug in at the point where it is called in the page?
Or is this a case that i do not fully understand how the plug in works and there is a much simpler way?
The only way i could get it to work was to move the code from the head of the page into the repeat region, maybe for the next update you could add another option to the wizard insert in head or where the cursor is?
