e-cart in Australia
Thread begun 4/19/2011 10:34 pm by welcomcat385026 | Last modified 5/13/2011 10:15 pm by welcomcat385026 | 7187 views | 18 replies |
welcomcat385026
e-cart in Australia
I have no joy to use e-cart in Australia. Paypal Website Payment Pro is not available here.
I do not get much support in Forum about issues.
Immediate issue is "currency". Unless I use checkout wizard with paypal website payment pro, I cannot find where I can change currency code from "USD" to "AUD". I tried "insert checkout form" and changed provider>edit>currency from "USD" to "AUD" I still ended up with the paypal page with $USD .Is there any way out with this issue?
Also is it possible to have multiple checkout pages with one shopping cart? My aim is "money goes to different Paypal A/C holders depending on purchaser's postcode."
Dave BuchholzBeta Tester
I have written several eCart sites now for australian clients all using PayPal Standard as the payment gateway and had no problem getting the cart to recognise AUD
On your confirm page look for a hidden form element called currency_code and change it's value to AUD rather than the standard USD
With regard to your second question that would take a fair bit of custom coding to achieve and I can see logistical issues in terms of tracking orders etc.
You might be better having separate "shops" as subdomains i.e. mygreatshop.mydomain.com, myothershop.mydomain.com etc. but if you lay out your business plan you might get better suggestions
welcomcat385026
Currency problem
Thank you very much. USD was changed to AUD successfully. I still have a headache with how I am going to work out with multiple checkout pages for each payment gateway.
Australia has a tough reseller, franchise law and one shopping cart cannot collect all the money from resellers sales, etc. etc. because of superannuation and tax and stuff.
Best regards,
No worries, I would suggest you contact a local accountant or business forum and ask about your issue as far as multiple resellers goes.
welcomcat385026
multiple checkout pages for one shopping cart
Hi Dave,
I also posted the question to Paypal X.com and I got an answer as follows. I start working on it now. Thanks!
In the code that your cart script sends to PayPal, it is the value you pass
for 'business' that determines where the payment should go to.
So you can have a script on your end that will dynamically change this value
as shown in the example below before posting to PayPal.
<input type="hidden" name="business" value="seller_email@paypal.com
(mailto:seller_email@paypal.com)">
You can find a list of the standard variables here
(DOC-1332)if needed.
welcomcat385026
Originally Said By: welcomcat385026
  Hi Dave,
I found "business" in confirm.php page. Postcode is variable and when the particular value is placed, it triggers action to go to one of confirm.php pages.Is that right? So postcode gets inserted in checkout.php which provides billing information. So where do I put PHP code to allocate a customer to particular confirm.php page? I am only a designer and not really good at coding. Can anybody help this?
use this code for the business tag to set it dynamicly based on the post code:
          $ppBusiness
          switch(isset(
$_POST['postcode'])?$_POST['postcode']:"") {
              case
"12345":
$ppBusiness "one@one.com";
                break;
            case
"678910":
$ppBusiness "two@two.com";
                break;
            default:
$ppBusiness "default@default.com";
                break;
          <input type="hidden" name="business" id="business" value="<?php echo($ppBusiness); ?>" />
welcomcat385026
ppBusiness "";
          switch(isset(
$_POST['postcode']?$_POST['postcode']:"") {
              case
"12345":
                break;
            case
"678910":
                break;
            default:
                break;
          <input type="hidden" name="business" id="business" value="<?php echo(ppBusiness); ?>" />
Thank you and I'll send a reply as soon as everything works out OK. (work disturbed by Easter Holiday)
You're welcome.
welcomcat385026
Parse error in confirm.php page
I set up 2 business account with PayPal. (took for a while) and reprogrammed "confirm.php" as follows:
<td><input type="hidden" name="business" id="business" value="<?php echo(ppBusiness); ?>" />
$ ppBusiness = "";
switch(isset($_POST['postcode']?$_POST['postcode']:"") {
case "4211":
$ppBusiness = "prf@generalincentives.com";
break;
case "4220":
$ppBusiness = "info@generalincentives.com";
break;
default:
$ppBusiness = "prfl@generalincentives.com";
break;
When I press checkout button in "confirm.php", the following error occurs:
Parse error: syntax error, unexpected T_STRING, expecting T_VARIABLE or '$' in /homepages/22/d343726250/htdocs/gi/testshop/confirm.php on line 256
*Line 256 is $ ppBusiness = "";
My test site URL : shop.php
