getDocumentDOM is not defined
Thread begun 4/19/2011 2:09 pm by metamind36157 | Last modified 4/20/2011 6:48 am by Jason Byrnes | 2966 views | 3 replies |
metamind36157
I'm a newby at this so this may be something simple I'm totally missing. I've installed most of the WA SuperSuite DW extensions on a Windows 7 64 bit PC. I'm using DW CS5.
I've installed XAMPP so as to be able to have a local dynamic Website I can use till I'm ready to publish to the Web.
Using Site Sculptor to try and set-up a basic Portfolio site, I'm encountering this error message, no matter what extension I use: WA_getDocumentDOM is not defined.
Right after that error message, I'll either get a javascript error notification which only enables me to close the message window, or I'll get an error generating "whatever I tried to do with any of the WA extensions".
Maybe an indication, when launching DWCS5, I get this error message: The following JavaScript error(s) occurred:
At line 21 of file "C:\Users....\DreamweaverCS5\en_US\Configuration\Shared\WebAssist\Preferences\RSSUpdate.js": WebAssist_getExtensionDataFromMXI is not defined.
I have no clue if there's any relationship between the 2 error messages, but I'm not getting anywhere fast here. Any help would be appreciated. Thanks!
Delete the Dreamweaver Cache file from the users configuration folder:
metamind36157
Cache File deleted
Thanks for this Jason, but, no cigar!
I forgot to mention I did that prior to even trying to post. So that cannot be the issue, unless you tell me that the cache file rebuilds itself messed-up?
