update via admin page
Thread begun 4/19/2011 7:07 am by i.edwards384429 | Last modified 4/20/2011 6:44 am by Jason Byrnes | 5687 views | 11 replies |
i.edwards384429
Hi
added a field called " paid" into the database varchar.
If I used phpmyadmin and type in the field "yes" then when I open Users_detail.php then the vsalue is echo'd to the form.
If I open users_update.php the value is again echo'd to the form.
If I delete the "yes" from the database using phpmy admin and then go to users_update.php type in yes and then select update the database table is not updated.
can't see why would appreciate someone looking at the code and teling what I've missed
thanks
Ian
the code looks correct. to trouble shoot, change:
$WA_redirectURL = "users_Detail.php?UserID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"")  ."";
//$WA_redirectURL = "users_Detail.php?UserID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"")  ."";
$WA_redirectURL = "";
then add the following code after the <body> tag to write the sql statement being used to the page:
<?php echo("SQL: ".$WA_Sql."<br />"); ?>
post back the sql after testing
i.edwards384429
update
Hi Jason
the sql is
Notice: Undefined variable: WA_Sql in C:\wamp\www\1stmodelagency\Admin\users_Update.php on line 168
line 168 is theline you toldme to add so I'm clearly not looking in the correct place
thanks
Ian
try using this code instead:
if (isset($_POST["Update_x"])){
echo(
i.edwards384429
update
Hi Jason
I substituted "<?php echo("SQL: ".$WA_Sql."<br />"); ?> " ( which I had placed after the opening body tag with "<?php
Now when I try to update I see no error message whatsoever and the table is still not updated
cheers
Ian
ok, sounds like the validation then.
change :
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"usersUpdate");
    die($WAFV_Errors);
and post the results after testing.
i.edwards384429
update
I say that did something ;-)
I've glad you understand it!!
cheers
Ian
Deprecated: Function split() is deprecated in C:\wamp\www\1stmodelagency\WA_ValidationToolkit\WAVT_Scripts_PHP.php on line 330
Deprecated: Function eregi() is deprecated in C:\wamp\www\1stmodelagency\WA_ValidationToolkit\WAVT_Scripts_PHP.php on line 547
,8,12,13,14
in the WAVT_Scripts_PHP.php search for:
split(
and change it to:
explode(
it should be found on lines 330 and 547
The string of numbers at the end:
,8,12,13,14
Means that validation for the UserPhone, UserState, UserZip and UserCountry are failing.
make sure those elements are properly filled in.
i.edwards384429
update
Hi Jason
Did some investigating and decided to create a new user registration and if it worked compare files etc.
I downloaded a new copy of the user registrstion and did virgin install to a new database.
I used the users simple registration and it accepted and wrote to the database.
I then logged into the users_Profile.php
added some details inc phone mumber went and wrote to the users table.
I exited and loaded admin\users_Update.php
searched for user
and then pressedthe pen icon to edit the user
changed the country and the city
pressed update
It tells me straight away to "Please Enter a phone number" despite one being there although it is the same format as in the user profile page and the same number.
if i type in 12345678912 I get the same message, if I continue to type in letters then I get told I have exceeed the maximum number of characters.
I can't get past this so it's stopping the update process.
Not sure if this was my initial issue but....
cheers
Ian
i.edwards384429
update
Hi Jason
got the form updateing - thanks fo rthe help.
I now need to add two additional form fields to update the database.
The two database fields are:
date_paid
paid
I added two rows to the table and place a text field in the appropriate colum.
in the initial value I selected the lightning bolt to fill with the value from the database.
However in the record set that opens I do not see my two additional fields in the record set wadausers.
If I double click on the record set and then select "test" the two colums date_paid and paid are shown.
what am I missing or am I approaching this the wrong way?
thanks
Ian
