Power Gallery and Jquery Conflict
Thread begun 4/19/2011 2:16 am by alistair316863 | Last modified 4/20/2011 7:49 am by alistair316863 | 2007 views | 2 replies |
alistair316863
Hi I am using the jquery nivoslider to display some images on my site on the same page I also have a power gallery ribbon gallery.
When the gallery is on the page then the images for the nivoslider will not load see: test.php
when i remove the gallery everything is ok see:
test2.php
The files that are associated with the nivoslider are:
jquery.nivo.slider.pack.js and
common4.js
Thank you Alistair
I think the problem is caused by having 2 different light box scripts on the page.
Power Gallery uses the Slimbox lightbox script and you also have the ShdowBox lightbox script on the page. The two are probably conflicting with each other.
alistair316863
Hi I have deleted the shadowbox from the page but still not loading, but I have changed it for now on the actual pages so its running a different script which works just a bit slow thanks Alistair
