Data Assist 404 Error when put to remote server
Thread begun 4/18/2011 9:03 pm by cicyou421883 | Last modified 4/22/2011 11:51 am by cicyou421883 | 3320 views | 4 replies |
cicyou421883
Created Product_Detail page in Data Assist with MAMP and Dreamweaver CS5 template, localhost shows page, put to remote server, error message below. I searched for root directory on my Apache httpd.conf and index.htm was added. Not working. cannot find anything incorrect about the directory. Any other suggestions? Error message:
Not Found
The requested URL /products_Detail.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache Server at californianatural.co Port 80
this means that Dreamweaver is uploading the file to a different location than the address you are using to access it.
cicyou421883
Your response
Hey Jason, Thank you for your reply. I do not understand since without Data Assist and MAMP the file from Dreamweaver loads fine. I cannot see how the database instructions that Data Assist uses changes the put location to remote server. The localhost (alt f12) shows the file. I have put hundreds of files to remote servers fine and my purchase with Data Assist using MAMP PRO change this to error. Any more suggestions since I cannot figure the correct path that Data Assist gave.
cicyou421883
Problem Solved
Jason - I did clean up my root directory and my /hosts/ to resolve this problem. Thank you for you time on Wednesday. I just sent a rply on the other posts since I am back to the original problem.
