Maximum quantity of any item per transaction
Thread begun 4/18/2011 10:01 am by marovios@yahoo.com | Last modified 4/25/2011 7:26 am by Jason Byrnes | 2628 views | 5 replies |
marovios@yahoo.com
Hi all, I have an unusual question.
I need to limit the quantity of any item being purchased to 40 per transaction.
A sample scenario would be like this: I'm a user and I purchase 12 items of one product, another 12 from another product and 16 from a third product. I end up with 40 items total. In this case I can continue to check out. But, if I try to purchase more than 40 items I should be stopped by the system. As a user I shouldn't be allowed to purchase more than 40 items (of any products, that doesn't matter) on the same order. If I need to purchase 45 items for example, then I should place an order for 40 items and then another order for 5 items.
Is this possible? I guess I would have to deal with the "Total of Quantity" session if it exists, am I right here? How can I achieve this?
Thanks much!.
on the cart page, add an if statement around the checkout button to check the c=total cart quantoty and only show the checkout button if the quantity is 40 or less:
<?php if($<your cart name>->TotalColumn("Quantity") <= "40") { ?>
<checkout button>
<?php } ?>
you can use a similar if statement to show an error message if the quantity is greater than 40:
<?php if($<your cart name>->TotalColumn("Quantity") > "40") { ?>
error message
<?php } ?>
in both of these if statements, replace "<your cart name>" with the name of your eCart object.
marovios@yahoo.com
Thanks much for your help Jason. I will give it a try and let you know, seems it's what I have been looking for, a piece of code to handle the max quantity. Thanks!.
you're welcome.
marovios@yahoo.com
Just wanted to let you know that your code worked perfectly. Thanks much!!!!
Great, glad to hear it is working.
