PS 4.5 Gallery Issue after upgrade
Thread begun 4/18/2011 7:14 am by KiddaMan | Last modified 4/18/2011 11:20 am by KiddaMan | 3155 views | 8 replies |
KiddaMan
Good Morning Jason / WA Team,
I recently made the upgrade to PS 4.5, and all seem to be great except for my galleries. It seems the pre-existing galleries cannot fiind the images.
Please refer to the follwing link to observe page.php?News=2
here are updated copies of the galleries/global.php and webassist/framework/library.php file that should correct the issue.
KiddaMan
Thanks, I will give it a try and let you know.
KiddaMan
Jason,
I updated the files and put them to the server, but now getting this:
Warning: require_once(../Connections/powergallery.php) [function.require-once]: failed to open stream: No such file or directory in D:\Hosting\5972022\html\galleries\global.php on line 4
Fatal error: require_once() [function.require]: Failed opening required '../Connections/powergallery.php' (include_path='.;C:\php5\pear') in D:\Hosting\5972022\html\galleries\global.php on line 4
hmmm, revert back to the original galleries/global.php file it should only need the library.php update.
if you are still having trouble, i will start a ticket so we can investigate further.
KiddaMan
ok... will let you know.
KiddaMan
Sorry Friend,
It did clear the fatal error message and shows the page but will not recognize the pics.
KiddaMan
Thanks......
