HTML Editor 3 Compatibility
Thread begun 4/17/2011 3:46 pm by A Sound Design | Last modified 4/18/2011 8:48 am by Jason Byrnes | 2262 views | 3 replies |
A Sound Design
I've downloaded the Beta version as I do have HTML Editor. Do I need to add the patch under 'Known Issues - CSS Form Builder 2: Support Fix - A JavaScript error occurs when installing Form Toolkit after CSS Form Builder 2' ?? Or does that just relate to CSS Form Builder 2.0.0?
You will need to apply that update if you Install CSS Form Builder After installing Form Toolkit.
It is only need if form Toolkit is installed prior to installing CSS Form Builder.
That update does not effect any compatibility with HTML Editor.
it only effects CSS Form Builder 2 compatibility if Form Toolkit is installed first.
A Sound Design
I haven't installed Form Toolkit yet. So I don't really need to use the Beta version? Is that correct?
the javascript update you referenced before and the beta version are not the same thing.
you need to use the beta version if the following is true:
You are also using HTML Editor 3
If you are going to use HTML Editor 3, you must use the CSS Form Builder beta version.
