Two "Easy Ones" starting out
Thread begun 4/15/2011 3:04 pm by info22862 | Last modified 4/18/2011 6:54 am by Jason Byrnes | 2976 views | 4 replies |
info22862
I have used SA a few times, but it seems every time I get errors and issues I have to go in and fix.
# 1 When I want to create an entire registration system including login functionality.
Do I Open the TEMPLATE I want to base everything on and then insert? Or Do I open any page and select insert DataAssist Wizard?
#2 When I am asked to select a UNIQUE ID to check for Duplicates.
We are using the same field as the USERNAME as the UI.
However, it then asks to go to a page if there is a duplicate, we have a physical page and select it, but receive and error stating, This page is not based on your template? However, it is based on our template? Whats up?
If anyone has a few set up tips before you run the wizard, I would greatly appreciate your sharing.
info22862
Additional info
I am using PHP MySQL
When I complete the initial registration page, the page inserts into the database but then goes nowhere. Just a blank page. Everything looks right, proper page is set for the redirect, but nothing it goes nowhere?
CraigRBeta Tester
if you are getting a blank page after insert, it sounds like your php page has an error.
add the following code to line 1 to check...
error_reporting(E_ALL);
info22862
Your awesome for responding on a weekend!
I get the following message:
Warning: Cannot modify header information - headers already sent in /mnt/stor10-wc2-dfw1/562440/www.creditcounseling101.com/web/content/Templates/applicant_Registration.php on line 93
Here are lines 88-95
88 $insertGoTo = "/Templates/applicant_LogIn.php";
89 if (isset($_SERVER['QUERY_STRING'])) {
90 $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
91 $insertGoTo .= $_SERVER['QUERY_STRING'];
92 }
93 header(sprintf("Location: %s", $insertGoTo));
94 }
95 ?>
Thanks again for your timely assistance!
Jerry
The headers already sent error usually includes a section in parenthesis that starts "Output started at" this is the key section of the error for troubleshooting the cause.
see this thread for details on troubleshooting the header already sent error:
showthread.php?t=19285
to answer the initial questions:
1) you can have any page from your site open when you start the security assist wizard, it should not be the template.
2) That error means that the go to page is not based on the template that was selected on the first page of the security assist wizard. on the first page of the security assist wizard, you can select your site template from a drop down list and set the editable region for the security assist content to be placed in, if you do not select a template on the first step of the wizard, but select a page that is based on a template for the go to page, you will get that error.
