PowerCMS and PowerGallery
Thread begun 4/15/2011 7:16 am by david390068 | Last modified 4/15/2011 9:17 am by Jason Byrnes | 2190 views | 3 replies |
david390068Beta Tester
I have intalled powercms and powergallery for use on the same site. How do I get PowerCMS
to save the PowerGallery code and display it on the site pages?
My PowerCMS takes the code as:
<img design="ribbon_lightbox" id="1" name="powergallery" src="light_large.png" style="display:block" theme="light" />
In PowerCMS developer notes it shows:
include('C:/wamp/www/cmsgallery/cms/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'Content', true);
Trying to display on website using:
require_once('wa_evaluate.php');
include('/cms/WA_CMS/addtosite.php');
The page just shows the powergallery image place holder.
What am I doing wrong or is there an additional setting I need to change?
In Power gallery, go to the add to site section for your gallery and copy the code From the Add to Power Store, it will look similar to:
<input type="hidden" name="powergallery" id="1" theme="dark" value="/Applications/MAMP/htdocs/pg/galleries/ribbon_fullsize_lightbox/index.php" />
you then need to modify the PowerCMS developer notes code to wrap the wa_evaluate() function around the WA_getCMSContent() function.
change:
echo wa_evaluate(WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'Content', true));
Thanks Jason. Will the image place holder still show up in the ckeditor as it does now?
It shouldnt, the code to enter from the Power Galley add to site section is not an image tag, it is a hidden form element.
