Price increasing
Thread begun 4/15/2011 6:46 am by moz1104419172 | Last modified 4/25/2011 1:39 am by moz1104419172 | 3144 views | 4 replies |
moz1104419172
Price increasing
Is there a simpler method to increasing the price of an item rather than needing to use the recordset information and the product option table in the database, there would be nothing dynamic depending on which item is shown, just that if a checkbox is clicked (or even better, if a text entry field is not empty), then the price increases £4.
sure, that can be done.
add a new column for your option, for the sake of example, lets call it "itemText" set the unique attribute for this new column. in the add to cart button, set the itemText column to updatable from a text box.
now in the eCart object, go to the calculations tab, create a new calculation called realPrice:
(abs([itemText]!='')?[Price] + 4:[Price])
and update the total Price calculation to:
(abs([itemText]!='')?[Price] + 4:[Price]) * [Quantity]
when you create the cart display page, on the second page of the cart display wizard, remove the column for price, and add the realPrice column in it's place.
moz1104419172
Thats fantastic it seems to be working a treat, is there any way it could alter the price on the page in real time? so it would add the cost to the price value at the bottom when its not empty, and go back to its original value if it is
many thanks
You would need to hand code a javascript function on the page to accomplish that, we do not offer support for hand coding javascript.
moz1104419172
I thought that would be the case, thanks anyway
