Regular expression validation is working clientside but not serverside
Thread begun 4/15/2011 4:24 am by Rune Brynestad | Last modified 4/18/2011 8:07 am by Jason Byrnes | 2959 views | 3 replies |
Rune Brynestad
I have an Userid with the following syntax: It starts with the uppercase letters SSF followed by \ and a lowercase letter c. Then it's 3 numbers and 3 letters. (Example: SSF\c890rbr). I believe the regular expression for this should be /^SSF\\c\d{3}[a-zA-Z]{3}$/
The validation is working clientside but not serverside. The problem with the serverside validation is that a valid userid does not pass through.
You can test it on live URL here
Serverside: Serverside.php
Clientside: Clientside.php
I'm attaching my working files. I would very much like the serverside validation to work.
Thanks in advice.
Regards
Rune
the server side regular expression should be:
/^SSF\\\\c\d{3}[a-zA-Z]{3}$/
in PHP you need to use four slashes to escape the one:
in javasctipt, you can use just the 2:
Rune Brynestad
Works perfect.
Thanks again.
Regards
Rune
you're welcome.
