Local checkout
Thread begun 4/14/2011 10:15 pm by welcomcat385026 | Last modified 4/19/2011 1:40 am by welcomcat385026 | 3623 views | 7 replies |
welcomcat385026
Local checkout
Programming local checkout.
my checkout.php not corresponding to paypal (Transaction wouldn't happen)and when I fill out checkout form, error happens 'cannot find failure.php file' File path is right but transaction wouldn't happen. Paypal API username, password, signature are right.
please post a link where i can test this.
welcomcat385026
local checkout
I fixed failure transaction issue. However checkout.php looks like not communicating with Paypal Gateway at all. Paypal Express button doesn't do anything either. Username, password, signature are from Paypal profile/API credential. I copied them and pasted on the fields in checkout insert form interface. My shopping site is : waterfiltershopping.php
I'm not using sandbox and instead put a temporary $1.00 item at the bottom.
When I used the checkout wizard, cart was working properly, however I didn't like redundancy of the checkout given and needed to simplify the process using local checkout. Best regards,
welcomcat385026
Paypal Websites Payment Pro
To use local checkout, do I need to sign up for Website Payment Pro?
If it's true, the above issue might be a cause of the problem.
Best regards,
welcomcat385026
My e-cart used in Australia
I am really confused now since I found out Paypal DirectPayment has many restrictions over countries outside US, Canada, UK. How does Paypal integration work with e-cart under my setting.
Payment Gatewsay: Paypal
Currency AUS dollars
One more question:
API signature has two sections connected by hyphen. One of your documentation says "Use the section after hyphen.' Is that correct? Best regards,
welcomcat385026
shop.php
I made another test site and could reach to confirm.php page, however a transaction didn't go through.
The checkout.php form doesn't indicate how user should put card No. with space between
and also the expiry date and year should be "02" , "February" , "2" , "/11", or "2011"etc.
If the value is wrongly put, a transaction wouldn't go through?
Another problem is : when I use insert checkout form wizard, even if I put file destination path, all ended up in top hierarchy with index file. Doesn't this cause a problem if you have more than one shopping cart in different sub files? I shifted all the necessary files in subfile"shopping" and change file link manually. Please check this issue with your software wizard. Best regards,
welcomcat385026
Paypal Website Payment Pro is not available in Australia
Originally Said By: welcomcat385026
  shop.php
I found Paypal websitePaymentPro is not available. Payflow Pro ($200 setup)is only alternative. However they are making it available to Australians toward the end of this year. Hope it happens. Is there any solution to create local checkout with e-cart for Australians without setup cost.
welcomcat385026
/ was missing after a subfile
  shop.php
Slash(/)was missing after a subfile.
