Cart still has items after checkout is complete
Thread begun 6/30/2009 11:10 am by fcoloccia331860 | Last modified 6/30/2009 12:01 pm by fcoloccia331860 | 3294 views | 4 replies |
fcoloccia331860
I have my cart working and all, but once I checkout successfully, the cart is not empty. In other words, I had Item 1A to my cart, go through checkout and process successfully. From there, if I go an add another item to the cart, say 1B, the cart still is showing 1A and also show 1B.
And if I continue with the checkout, it doesn't insert a new order in the DB, it just replaces the one with 1A.
So the sessions are not empty after the checkout, isn't there a way to do this?
You can clear the session on the bottom of the success page after the payment is processed. The syntax depends on your server language.
fcoloccia331860
I'm using ASP VBScript...
Session.Abandon()
Just place it at the bottom of the page where you want the session cleared.
fcoloccia331860
beautiful...thanks.
