I moved a site I have working
Thread begun 4/14/2011 2:39 am by hdavis136190 | Last modified 4/15/2011 8:50 am by Jason Byrnes | 3392 views | 4 replies |
hdavis136190
to an other site, that will be it's home. I get this error on the new site, where it all works on the site that I was working on. Why would it have an issue on one site and not the other?
Thanks for any ideas.
Warning: mysql_pconnect() [function.mysql-pconnect]: Lost connection to MySQL server at 'reading initial communication packet', system error: 113 in /home/content/16/7558216/html/RxCuts/Connections/sfcvha.php on line 11
Fatal error: Lost connection to MySQL server at 'reading initial communication packet', system error: 113 in /home/content/16/7558216/html/RxCuts/Connections/sfcvha.php on line 11
This can happen if you are not using the correct address in the connection for the MySQL Server.
try using "localhost" for the MySQL Server address, if this does not work, contact your host to determine the correct address to use.
hdavis136190
Why would the first site work then, all I did was copy the complete site to another site, all the files are the same, if the SQL sever address was wrong then it should be wrong at the first site too, I would think.......
hdavis136190
ok found out the issue
The ISP I am using for both sites, controls MySQL DB's as internal/external, one was set to Ext the other Int, who knew, I know I should have :) Thanks for the comments
Glad to hear you have it working.
