BCC addresses show in email body
Thread begun 4/13/2011 8:54 pm by Timespider | Last modified 4/15/2011 1:46 pm by Jason Byrnes | 2499 views | 3 replies |
Timespider
Hello, I have a multiple select menu set up in a page for the BCC which all works fine. But when I check the emails the email addresses I have sent it to using the BCC show up in the body, this addresses showing only happens with a multiple select or multiple checkboxes. When I use the loop through recordset system(I have on other pages) everythings fine , it also sends the value of the send button as well(this button value happens on all pages I use UE on), & if I leave the button value empty it appears as "submit query" in the body.
Does anyone have any ideas?
Thanks Chris
in the webassist/email/templates folder, open the template file for your email.
In code view, near the top will be the following code:
$removeBegins = array();
$removeBegins[] = "Security";
add new items using the name of your submit button and select list. for example, if the select list is name "bcc_select" and the submit button is named "email_submit":
$removeBegins[] = "bcc_select";
$removeBegins[] = "email_submit";
this will ignore those form elements in the email body
Timespider
Thanks Jason that did the trick. Is this something I'll have to do every time I set up UE this way?
Also just a side note. I read these forums first & search certain things to find an answer before making a post, but when I find a suitable post & save it in my browsers favourites the next time I click that favourite, it says no records found. Like this one for example.
search.php?searchid=1388009
Why does this happen?
Thanks again, Chris
Yes, you will need to add any form elements you want to suppress in the email to the remove array.
When you search the forum, you cannot bookmark the search results, the search results are stored in a session which is destroyed when you close you're browser.
You can bookmark individual threads while viewing them however.
