add more than one bcc recordsert field
Thread begun 4/13/2011 10:13 am by mr hankey | Last modified 4/13/2011 10:38 am by Jason Byrnes | 1461 views | 1 replies |
mr hankey
hi,
in the UE wizard i am unable to add more than one recordset email address field?
is this possible?
everytime i seperate the email with say a , and select the lightning bol and choose the next recordset field it automatically changes the one that is in there rather than adding it to the list.
can this be done at all?
what should i seperate with if i have to do it manually?
many thanks
after you select the first recordset column, copy the code that is added to the cc field, then select the second recordset column, add the comma, and paste the code for the first recordset column back in.
