Nested repeat region in a spry accordion
Thread begun 4/13/2011 9:07 am by John Langer | Last modified 8/22/2014 10:07 am by Jason Byrnes | 13185 views | 13 replies |
John LangerBeta Tester
Hi
I've attached the files.
I have a spry accordion. The labels and content are coming from two separate MySQL tables. I have the content in a DataAssist repeat region and then the whole accordion in another repeat region.
The panels are repeated, The labels are repeated OK. The first panel shows the repeated content as a list, the second panel (Publicity) is empty but should have another repeated list of content.
Here's a link to the webpage in question (just a basic style, I'm just trying to see if it works).
If anyone could offer help with this I'd be grateful.
the code for the rs downloads recordset:
$colname_rsDownloads = "-1";
if (isset($row_rsDownloadCats['downloadCatID'])) {
  $colname_rsDownloads = (get_magic_quotes_gpc()) ? $row_rsDownloadCats['downloadCatID'] : addslashes($row_rsDownloadCats['downloadCatID']);
mysql_select_db($database_connCvmOrg, $connCvmOrg);
$query_rsDownloads = sprintf("SELECT * FROM members_downloads WHERE FKdownloadCatID = %s", GetSQLValueString($colname_rsDownloads, "int"));
$rsDownloads = mysql_query($query_rsDownloads, $connCvmOrg) or die(mysql_error());
$row_rsDownloads = mysql_fetch_assoc($rsDownloads);
$totalRows_rsDownloads = mysql_num_rows($rsDownloads);
needs to be moved so that is just before the second repeat selection:
<div class="AccordionPanel">
    <div class="AccordionPanelTab"><?php echo $row_rsDownloadCats['DownloadCategory']; ?></div>
    <div class="AccordionPanelContent">
      <ul>
= "-1";
if (isset(
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
    while(
$RepeatSelectionCounter_1_IterationsRemaining--){
        if(
$RepeatSelectionCounterBasedLooping_1 || $row_rsDownloads){
As usual Jason, you've cracked it.
Many, many thanks it works a treat now.
you're welcome.
MarkBeta Tester
Could be same problem?
Hi Jason,
Just wondered if you have any advice or help on my problem using a nested WA repeat?
I have an accordion also.
The header titles of the accordion comes from a recordset which lists all the continents (Select All ).
And the contents are loaded from a recordset which is made up of a Joined table of the header titles table, joined to the foreign key of the contents table.
My problem is that I can get the headers to display all the accordion titles etc (pulled from the Select all recordset) but I cannot get the contents to appear within each of the content of the relevant tabs of the accordion? The content recordset placeholder tag has been give a WA Repeat behaviour.
Any thoughts - bit of a challenge this?
turtletravel.co.uk/newindex2.php
K Reg, Mark
for doing this, you need to have 2 recordsets, one recordset that returns the parent items, and a second recordset that returns the child items, the second recordset needs to be nested inside the loop
the format of the code will look lie this:
-parent recordset
-parent recordset loop
--write label
--child recordset, filters using the ID from the parent recordset
--child recordset loop
---write child info
--end child recordset loop
-end parent recordset loop
Sweens
Hi Jason
I'm trying a similar thing with a bootstrap accordion. I get the outer repeat OK, but the records in the inner repeat aren't tied to the selected item (in this case, a date).
I have tried using a WA Repeat selection, but the page keeps timing out, so the attached uses the standard DW Repeat Region.
Any help much appreciated, as ever
Chris
need more info.
i dont follow what you mean by this. I'm nit even sure what section of code i should be looking at.
Sweens
Sorry, Jason;
The folowing is the complete repeat region:
<?php if ($totalRows_rsDates > 0) { // Show if recordset not empty ?>
<div class="col-sm-5">
<div class="panel-group" id="accordion">
<?php do { ?>
<div class="panel panel-default">
<div class="panel-heading">
<h4 class="panel-title">
<a data-toggle="collapse" data-parent="#accordion" href="#collapse<?php echo $row_rsDates['ref']; ?>">
<?php echo $row_rsDates['mnu_date']; ?>
</a>
<p class = "pull-right">confirm | update | delete</p></h4>
</div>
<div id="collapse<?php echo $row_rsDates['ref']; ?>" class="panel-collapse collapse <?php /*START*/ if ($rsDates['RNo']="0"){ ?>
in<?php /*END*/ } ?>">
<div class="panel-body">
<?php do { ?>
<?php /*START*/ if ($rsFutMenus['ref']==$rsDates['ref']){ ?>
<img src="../img/products/thumbs150/<?php echo $row_rsFutMenus['ProductImage']; ?>" /><?php echo $row_rsFutMenus['ProductName']; ?> £<?php echo $row_rsFutMenus['ProductPrice']; ?> | <?php /*END*/ } ?>
<?php } while ($row_rsFutMenus = mysql_fetch_assoc($rsFutMenus)); ?>
// reset the recordset after a repeat region
mysql_data_seek($rsFutMenus, 0);
// get the first row from the recordset
$row_rsFutMenus = mysql_fetch_assoc($rsFutMenus);
</div>
</div>
</div>
<?php } while ($row_rsDates = mysql_fetch_assoc($rsDates)); ?>
</div>
</div>
<?php } // Show if recordset not empty ?>
The 'inner' part of the accordion is
<?php do { ?>
</div>
</div>
</div>
I've tried to relate the 'inner' to the tab heading by using <?php /*START*/ if ($rsFutMenus['ref']==$rsDates['ref']){ ?> but this just shows all records, for some reason.
Cheers
Chris
I Still don't follow, please provide more details on what it is you are trying to accomplish.
