Manage Designs Error
Thread begun 4/12/2011 10:04 am by eopco265885 | Last modified 4/12/2011 11:51 am by Jason Byrnes | 1252 views | 1 replies |
eopco265885
Hello:
I have Power Store 4.5 and it is up to date,. Right out of the blue, the enclosed error popped up when trying to edit Design changes in the Themes Section. Also, all of my design color changes, logos and such have reverted back to the default template. I saved everything and this does not make sense to me. If anyone can help, I would greatly appreciate it.
Rich
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in C:\wamp\www\costumescloseout04\webassist\plugins\styler\styler.php on line 117
