Editor Missing
Thread begun 4/12/2011 9:28 am by GrahamJ16 | Last modified 4/20/2011 6:22 am by Jason Byrnes | 5536 views | 7 replies |
GrahamJ16
Editor Missing
I have successfully installed PowerCMS builder but when I try to add / edit any content everything works fine except for there is no editor toolbar.
I can add / edit content OK but I have to write raw HTML in the editor box in order to style any content / add links etc.
The editor files are on the server OK but PowerCMS isn't using them.
I attach a screenshot to show my problem.
from the screen shot, it looks like you are using IE9, At this time Power CMS is not compatible with IE9, we will be releasing in the near future to address IE 9 compatibility. In the mean time you will need to use a different browser like Fire Fox.
GrahamJ16
No editor in Firefox
Thanks for the prompt reply Jason.
I did try IE9s different modes but with no success.
I attach a screenshot of the same page in Firefox and the editor doesn't appear in that browser either.
In fore fox, go to Tools -> Error console. What errors are reported in the error console?
GrahamJ16
CKEDITOR not defined
Firefox error console gives me the following error: CKEDITOR is not defined
The error link points at this line of code:
<script type="text/javascript">//<![CDATA[
CKEDITOR.replace('ContentValue', { "wa_preset_name": "Blank (custom)", "wa_preset_file": "(custom)", "width": "98%", "height": "300px", "skin": "kama", "docType": "<!DOCTYPE HTML PUBLIC \"-\/\/W3C\/\/DTD HTML 4.01 Transitional\/\/EN\" \"http:\/\/www.w3.org\/TR\/html4\/loose.dtd\">", "contentsLanguage": "", "dialog_startupFocusTab": false, "fullPage": false, "tabSpaces": "4", "filebrowserBrowseUrl": "..\/webassist\/kfm\/index.php?uicolor=%23eee&theme=webassist_v2", "toolbar": [ [ "Source", "-", "Preview" ], [ "Cut", "Copy", "Paste", "PasteText", "PasteFromWord", "-", "SpellChecker" ], [ "Undo", "Redo", "-", "Find", "Replace", "-", "SelectAll", "RemoveFormat" ], [ "Image", "Flash", "Table", "HorizontalRule", "Smiley", "SpecialChar", "PageBreak" ], "\/", [ "Bold", "Italic", "Underline", "Strike", "-", "Subscript", "Superscript" ], [ "NumberedList", "BulletedList", "-", "Outdent", "Indent", "Blockquote", "CreateDiv" ], [ "JustifyLeft", "JustifyCenter", "JustifyRight", "JustifyBlock" ], [ "Link", "Unlink", "Anchor" ], "\/", [ "Format", "Font", "FontSize" ], [ "TextColor", "BGColor" ], [ "Maximize", "ShowBlocks" ] ], "scayt_autoStartup": true, "contentsLangDirection": "ltr", "entities": false, "pasteFromWordRemoveFontStyles": false, "pasteFromWordRemoveStyles": false });
//]]></script>
This means that not all of the files from the webassist folder where uploaded to the server.
Make sure to upload the entire webassist folder to the server.
GrahamJ16
Problem Solved
I checked that all the files had been uploaded to the server, in fact I deleted the site from my local computer and downloaded from the remote server, set everything up on my local testing server and everything worked fine.
Looking at the source code of the contents_update.php page, I noticed a security restriction on showng the editor panel, I removed this and re-uploaded the page - everything worked fine on the remote server as well!
by removing the security restriction, this means anybody can access the contents update page.
You should probably put that back in.
Then try editing the WA_SecurityAssist/Helper_PHP.php file.
Change this code:
if (!isset($_SESSION)) {
    session_start();
if (!session_id()) {
    session_start();
kiebe
No HTML editor and can't edit content
I use XAMPP on Windows 7 with DWCS4. Have successfully installed the PowerCMS Builder extension and activated it.
There are a couple of problems with the installation:
1) There is no HTML editor when I try to edit the text in the CMS. This has been checked on three browsers FF, IE & Chrome. Have followed the steps above in this thread - but the problem remains.
2) When I try to edit the content in Dreamweaver I get the following error
C:xampp\htdocs\xampp\SiteName\PCMS_Edit_ContentID_<![CDATA[1]]>_Temp.php contains an invalid path.
Please let me know what needs to be done to fix these issues
you reported this issue in another thread, i started an incident for the other thread to investigate the problem with you.
