Contact Form has huge blank space above the form
Thread begun 4/09/2011 8:32 am by brendafos379366 | Last modified 4/11/2011 7:01 am by brendafos379366 | 3642 views | 2 replies |
brendafos379366
I'm using the Webassit/Forms/Insert New Form. I've used many times before. But now I'm having a problem with it putting a huge blank space above the form. I tried it a couple of times and got the same problem. I think it may be a problem with the Progress Bar thing? The form works - this may be a css issue?
Here's a link contact.php
neilo
Hi Brenda,
You could try adding a float: left; property to your form.Cool_Default rule at about line 84 of your fd_cool_default.css stylesheet:
fd_cool_default.css (line 84)
form.Cool_Default {
color: #B6B6B6;
float: left; /* Add this */
font-family: Arial,Helvetica,sans-serif;
font-size: 11pt;
margin: 0;
padding: 0;
width: 520px;
[Alternatively, you could instead add an overflow:hidden to the same rule. Either should work]
brendafos379366
The float:left fixed it. Thanks, so much.
Webassist is always helpful.
