Custom Log Entries - JavaScript Error
Thread began 4/07/2011 11:07 am by Andrew Read | Last modified 4/07/2011 11:25 am by Andrew Read | 1067 views | 1 replies |
Andrew Read
Hello,
I am attempting to have some custom log entries entered when I am sending out bulk emails. When I try to apply them to the server behaviour I get a JavaScript error.
I have added this to the top of the email body template page:
global $RecipArray;
global $RecipIndex;
and in the message body I am using the following code succesfully:
<?php echo($RecipArray[$RecipIndex][0]["yourColumnName"]); ?>
However, when I use that code in the logging section of the UE Wizard I get the JavaScript Error:
  "While executing applyServerBehaviour in CreateEmailMessage_WA.htm, a JavaScript error occurred."
Any ideas here?
Andrew Read
Solved for now...
I kind of reverse engineered this problem to solve it.
I added the fields using a known working session variable, then entered the RecipArray variable directly into the code on the email page.
Once I entered the wizzard again I found the issue to be, wrong quote type used:
Suggestion from the forums was:
<?php echo($RecipArray[$RecipIndex][0]["YourColumnHere"]); ?>
Only this actually works:
<?php echo $RecipArray[$RecipIndex][0]['YourColumnHere']; ?>
