Linking Issue
Thread begun 4/07/2011 9:08 am by hbibizadeh396670 | Last modified 4/07/2011 12:19 pm by Jason Byrnes | 2979 views | 5 replies |
hbibizadeh396670
Linking Issue
Hi
I have made a comment system for my website. Although the system works fine I have found an issue.
When a user submits a comment, they can add a url to their website.
In the posted comments, the name of the user is set up to be a link to the url field in the database.
The problem is if the user does not submit a url with their comment the link still appears and links to a blank page.
How to I make it so the name field only has a link is a link is submitted with a comment
Thanks in advance
by using an if statement around the anchor tag to only show if the recordset contains a link.
I would need a copy of your page to give you exact code to use.
hbibizadeh396670
Here
Thanks for this
change:
<a href="<?php echo $row_Posts['URL']; ?>"><?php echo $row_Posts['URL']; ?></a>
<?php if($row_Posts['URL'] != "") { ?>
<?php }  ?>
hbibizadeh396670
Thanks for your help.
I would just like to ask if it would be possible for you to delete my attachment above.
If you dont mind.
no worries, it's deleted.
