Email appears to work but nothing received
Thread begun 4/06/2011 10:43 am by michael287412 | Last modified 4/08/2011 6:43 am by Jason Byrnes | 8891 views | 9 replies |
michael287412
Hi - have set up Universal mail - taken 2 days to sort out accessing PEAR, I'm on a VPS with Webfusion running Plesk which has been a major headache accessing PEAR and getting past an open_basedir issue.
Using UE 4 on CS5
SMPT is with AuthSMTP
The script appears to run, from either a 'on page load' and 'form submit' but nothiong is being received. In both cases a GoTo Page functions. And there are no error messages.
I am using a valid from address within the domain.
What have I missed please
Thnaks Michael
on the go to page, add the following code just after the body tag:
<pre><?php var_dump($_SESSION); ?></pre>
this will tell us whether the email is being successfully passed to the smtp server or not.
if it is being sent to the SMTP server successfully, then either the SMTP server setting in universal email is not correct, or the SMTP server is refusing the relay the mail message to the recipient.
michael287412
Hi I get NULL displayed on the goto page
sorry, change the previous code to:
<pre><?php
@session_start();
?></pre>
michael287412
A bit more this time
array(12) {
["waue_mailmc_2_Total"]=>
int(0)
["waue_mailmc_2_Index"]=>
int(0)
["waue_mailmc_2_Remaining"]=>
int(0)
["waue_mailmc_2_Log"]=>
string(194) "Sending To: michael@eklegein.co.uk... 10002 - authentication failure [SMTP: Invalid response code received from server (code: 501, response: 5.5.4 cannot decode AUTH parameter)] - Failure
["waue_mailmc_2_From"]=>
string(32) "noreply@jesusjoypublishing.co.uk"
["waue_mailmc_2_To"]=>
string(22) "michael@eklegein.co.uk"
["waue_mailmc_2_Subject"]=>
string(5) "carla"
["waue_mailmc_2_Body"]=>
string(0) ""
["waue_mailmc_2_Header"]=>
string(82) "Message-ID=<605424098.14709c93a006be9459946e2e08bb0186@jesusjoypublishing.co.uk>;
["waue_mailmc_2_ErrorFunctionCalled"]=>
int(0)
["waue_mailmc_2_Error"]=>
string(140) "10002 - authentication failure [SMTP: Invalid response code received from server (code: 501, response: 5.5.4 cannot decode AUTH parameter)]"
["waue_mailmc_2_Status"]=>
string(7) "Failure"
From this:
it looks like there is a problem with passing the user name and password to the smtp server.
In the Universal Email settings for the SMTP server, did you check the box to pass authentication?
Are you sure the username and password entered are correct for making a connection to the smtp server?
I have found a couple of posts on google where the "saslauthd" service on the server needed to be restarted, try having the host restart that service.
michael287412
Hi Jason
Have checked all details - but all connections are OK, I have also tried to my ntlworlhd.com server and that took and age before timing out.
Have rebooted server but no change - have asked WebFusion for location of saslauthd is to restart - awaiting their as to often slow response
AuthSMTP have asked what authentication method is in use - i.e.
PLAIN, CRAM-MD5 they recommend CRAM-MD5 - is this set by UE or the server please?
michael287412
Jason
I realised late last night that I had not put the correct statement into UE had put mail.ntlworld.com and not smtp.ntlworld.com. The result is the same - ie. no transmission of email BUT I gset a slightly diffreent message, below, which may assist in identifying the issue.
array(12) {
["waue_mcmail2_1_Total"]=>
int(0)
["waue_mcmail2_1_Index"]=>
int(0)
["waue_mcmail2_1_Remaining"]=>
int(0)
["waue_mcmail2_1_Log"]=>
string(250) "Sending To: michael@eklegein.co.uk... 10001 - Failed to connect to smtp.ntlworld.com:25 [SMTP: Invalid response code received from server (code: 421, response: aamtaout03-winn.ispmail.ntl.com connection refused from [109.104.92.194])] - Failure
["waue_mcmail2_1_From"]=>
["waue_mcmail2_1_To"]=>
["waue_mcmail2_1_Subject"]=>
string(2) "gh"
["waue_mcmail2_1_Body"]=>
string(0) ""
["waue_mcmail2_1_Header"]=>
string(82) "Message-ID=<710883272.14709c93a006be9459946e2e08bb0186@jesusjoypublishing.co.uk>;
["waue_mcmail2_1_ErrorFunctionCalled"]=>
int(0)
["waue_mcmail2_1_Error"]=>
string(196) "10001 - Failed to connect to smtp.ntlworld.com:25 [SMTP: Invalid response code received from server (code: 421, response: aamtaout03-winn.ispmail.ntl.com connection refused from [109.104.92.194])]"
["waue_mcmail2_1_Status"]=>
string(7) "Failure"
This error means that the smtp server is not accepting the connection for some reason, you will need to work with the host to determine why the smtp server is not allowing connection to be made. It could be that the ip address (109.104.92.194) is being blocked, or the from address could be blocked, or the username and password could be the problem.
At this point UE is trying to hand off the email to the smtp server to be relayed, but the SMTP server is not allowing it to happen, this is an issue with the server.
