4.5 PowerStore New Install -
Thread begun 4/05/2011 1:25 pm by Art | Last modified 11/28/2011 8:59 am by Jason Byrnes | 2725 views | 3 replies |
Art
I tried doing this a number of times now and I get the same result each time.
ERROR: Database could not be created.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'CREATE TABLE IF NOT EXISTS `ps4_categories` ( `CategoryID` int(11) NOT NUL' at line 1
FYI, I had a support ticket on another issue where the 1000000000.00 on line 1257 (`ps4_shippingrates`table) was causing an error when I was trying to install. Support was "padding" that field with a large number. I downloaded 4.5 and that line still had the same amount. I remove 2 zeros and it works.
phillipcox143131
Getting same issues
I have the same issues so much for out of box setup why we cant just run the script direct i have no idea but have been trying for 5 days now to get this thing to work
first promblem i get is
I have managed to replace all the install folder and get it to go further but then it did once create all the tables but gave me a blank page so i am getting frustrated now and i thought that this would be such an easy job to get it working as i have purchased so much off Webassist
