ECart Weight Unit Error
Thread begun 4/05/2011 10:22 am by scaphis417771 | Last modified 4/26/2011 7:02 am by Jason Byrnes | 5897 views | 10 replies |
scaphis417771
I am trying to process an order and get this message on Shipping Failure page
LBS3LBS is not a valid unit of measurement for weight for this shipment
Can you tell me what I have done incorrectly?
On the confirm page, double click the server behaviors fro the Shipping rate Lookup service of your shipping provider, the last step of the server behavior, one of the settings is for wight units, the error is saying that this is set to "LBS3LBS", it should be just "LBS"
scaphis417771
Ok can you answer one more question
Thank you, that worked.
I must have something else wrong. I have a 3 lb item for ups and the shipping is $55.31. Do you know where I would look for these errors.
Thanks,
Janice
scaphis417771
Got It
Got It - Thanks for all your help.
you're welcome.
Dave BuchholzBeta Tester
Just following this up as I have run into the same issue
I have exactly the same issue after running the eCart checkout wizard, the relevant block of code looks like this:
if (WA_eCart_UPS_IsTrueValue("true")) {
      $Shipping_PackageArray[] = array();
      $Shipping_PackageIndex = sizeof($Shipping_PackageArray)-1;
      $Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$eCart1->DisplayInfo("Quantity"):1);
      $Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
      $Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "".WA_eCart_FormatNumber($eCart1->DisplayInfo('Quantity'), true, 1)  ."";
      $Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "".strtoupper($eCart1->WeightUnits)."S"  ."";
      $Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($eCart1->TotalColumn('TotalWeight'), true, 1)  ."";
      $Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "02";
      $Shipping_PackageArray[$Shipping_PackageIndex]["SizeUnits"] = "IN";
      $Shipping_PackageArray[$Shipping_PackageIndex]["PackageLength"] = "0";
      $Shipping_PackageArray[$Shipping_PackageIndex]["PackageWidth"] = "0";
      $Shipping_PackageArray[$Shipping_PackageIndex]["PackageHeight"] = "0";
      //Special Services
and on checkout I am always sent to the shipping failure page with the message: S is not a valid unit of measurement for weight for this shipment
I cannot find any reference to WeightUnits as in $eCart1->WeightUnits in the ecart files so how should this info be pulled in or is it a bug ?
It is a bug in ecart that it is using the wrong code.
the correct code for this line:
is:
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "".strtoupper($eCart1->WeightSuffix)."S"  ."";
Thanks Jason, I assume that this will be corrected in the next point release ?
Yes, it has been logged as a bug so it can be addressed for the next update.
excellent, thanks
