4 menu in one site but only the first is editable
Thread begun 4/05/2011 8:48 am by fandreani381737 | Last modified 4/12/2011 1:35 am by fandreani381737 | 3100 views | 4 replies |
fandreani381737
Hello again
I have four menu in one site, each has it's own directory cssmw cssmw0 cssmw1 cssmw2. Viewing the pages no problem. I have created a page copied from a model (not a very DW template) In this model there was the link to the cssmw1. I change it to the cssmw2 but when I try to open the edit interface I can see the menu structure of the first created menu the cssmw. what's wrong?
thank you for your help franz
send a copy of the page you are having this problem on please.
fandreani381737
Hi I'll send two files: loginemenu.php call the exact menu and the editor calls the right menu items, the loginscuola.php page is correct when viewing in the browser calling the correct menu, but editing it in DW (cs4) call the loginmenu.php menu items. I also clear the DW cache.
thank you
delete lines 118 - 129:
<script type="text/javascript" src="../CSSMenuWriter/cssmw1/menu.js"></script>
<style type="text/css" media="all">
@import url("../CSSMenuWriter/cssmw2/menu.css");
</style>
<!--[if lte IE 6]>
@import url("../CSSMenuWriter/cssmw2/menu_ie.css");
</style>
<![endif]-->
The first line references the wrong the js file, and it is duplicated at lines 134 - 145.
fandreani381737
It's Sounds Grate! Thank you for your patience
