Form Toolkit Captcha Validation Show If Error
Thread begun 4/05/2011 7:59 am by Suggs | Last modified 4/25/2013 6:50 am by Jason Byrnes | 3610 views | 7 replies |
Suggs
Hi Folks
Im getting the following error when trying to apply Validation Show If to Captcha in my Form Toolkit.
While executing onLoad in WAFV_ShowIfSB.htm, the following Javascript error(s) occurred:
At line 124 of file "C:\Program Files|Adobe\Adobe Dreamweaver CS4\Configuration\Commands\WAFV_ShowIfSB.js":
doSerialCheck is not defined
Im basically trying to show some text if the entered Captcha is wrong.
Your help will be greatly appreciated
Cheers
Delete the Dreamweaver Cache file from the users configuration folder:
Suggs
Hi Jason,
Already did this twice and reinstalled the plugin as well..still the same
Suggs
Hi Jason,
I've closed the ticket as ive deleted and reinstalled the plugin again and its worked this time round.
Best regards
OK, glad to hear it is working now.
Gizza372666
I have the same issue.
I did delete the Cache but the error is still there.
I am using Dreamweaver CS6
can you please help?
How did you fix this?
What extensions do you have installed including the version numbers?
The extensions that we offer that are compatible with DW CS6 are:
eCart 5
Free Tools 1.x
Design Extender 1.x
Data Bridge 1.x
If you have the stand alone version of Form Toolkit or Form Builder installed, you will need to upgrade to Data Bridge in order to use it in DW CS6.
